- Thread starter
- #31
No problem man. I found a good mod on this engine is to put fangs on the bottom bypass port. One fang in the middle of each transfer port. Also bringing the exhuast port up about .012. This mill will allow you to go this far with out having to modify your crank case. Will def wake this engine up.
thanks again
do you have any pics of what you did to th 4.6k sleeve?
this is only my second mod.
the first was a axial 28 that was isane when I finished it.
although, I got it too thin near edge of ports and the sleeve started to
deteroirate and I lost my pinch.
I'm down to one mill (4.6k) and two trucks. If I can make this k
a bad a$$ I may but anotherone to mod, they are soo cheap.
