Removing Paint
Chicagojoe
New Member
A couple of days ago, a guy I knew gave me a few bodies. The only problem is that he painted them himself, and it did not turn out too good. The bodies themselves are in perfect condition though. Is there any way that I can get the old paint off and then repaint it myself?
try varsol it takes off paint very well. or if not you can use goof off but I'm not sure how that will react with the lexan so just try it on a little spot first
oven cleaner!
seriously... i mostly do military models as a hobby, and when a tank or plane had a cactus paint job.. you could use oven cleaner to strip the paint but would leave the plastic alone! i do reccomend a test spot though!.... cant be too carefull as i haven't tried on polycarb.
adam
