Got My New Diffs?
SAVDOG
So I Got My New Diffs Today The 4 Spider Gears With Shimes And Hardened Cups. My Question Is There Any Grease Or Oil Inside Already? Or Do I Have To Do That My Self? If So What Do Ya Reccommened? And How Much Do Ya Fill It? Also What Is Good Grease To Use For The Outside Gears? Let Me Know Thanks.
i got the same diffs and they where oily so i just put them in and greased the ring gear with auto grease and ran them no problem and 8 tanks of fuel so far
Thanks 420 I Was Wondering If There Was Oil In Them. I Didn't Want To Burn Them Up. Thanks For The Info.
Grease
Yeah I would make sure you check them for lube.Just be careful that the diff gasket doesn't split on disassembly. I use regular auto wheel bearing grease inside and a product called Transgel on the ring and pinion only because I get those for free!I have never had a lube related failure but I know most guys like to use silicon oil in theirs.Also make sure you use Loc-tight on the 4 ring gear screws and make sure they are tight.If you can replace those Phillips heads with hex type and while your there make sure the backlash is set correctly between the ring and pinion.
Dave
Nice Thread Yes It Did Help But The Diffs I Bought Already Had The Shimes? And 4 Spiders
I HAVE THE SAVVY 25 BUT YOU MIGHT AS WELL SAY IT IS AN X I MODDED IT TO THE MAX. THE DIFFS I BOUGHT ARE THE ALUMINIUM CASED/ HARDENED CUPS /4 SPIDER GEARS AND SHIMES I JUST DIDN'T WANT TO TEAR INTO THEM IF I DIDN'T HAVE TO. HEY PINE CHECK THEM OUT HERE IS THE Item number: 270194463431 ON EBAY SEE WHAT YA THINK THANKS.
HEY PINE I HAVE THE SAVVY 25 BUT YOU MIGHT AS WELL SAY I HAVE THE X I HAVE MODDED EVERY PART ON THE TRUCK. HERE CHECK OUT THE DIFFS I GOT ON EBAY Item number: 270194463431 SEE WHAT YA THINK.
Cool diffs and great price as well.You want to check backlash anyways-this is the play between ring gear and pinion gear when assembled.You want to feel a little gap between the two while holding one still.Too much and pinion tooth will break,too little and both will wear fast.See that thread for more info or search diff here-lots of threads on it.
Dave
It's just a matter of adding or removing shims between side bearing and diff case to move assembly closer to or away pinion gear.
Dave
