Bought New Diffs With 4 Spiders And Shimes Got Question?
SAVDOG
I Bought The New Aluminium Diffs With The 4 Spider Gears And The Added Shimes. What I Would Like To Know Is What Is The Best Diff Fluid To Run And Also What Kind Of Grease To Put On The Outside Gear? If Anyone Has A Suggestion Let Me Know Thanks. Savdog
Any kind of fluid is ok, What your looking at is the weight ... I run 50,000 all around.. And for the outside gears I just get some black grease and use alot of it.
So Black Grease Do You Mean Just Any All Purpose Grease? Also What Weight Diff Fluid Comes In The Diffs?
I pack the outside of my diffs with bearing grease, and I mean pack them. Haven't had a problem with the ring and pinion ever. As for the diffs I put a locker in the rear since I got tired of replacing the spider gears. I'm with SJ on using the thick diff oil. It creates a limited slip effect. Peace
If their isn't anything on the ring and pinion gears would that cause them to click?
The X 4.6 was almost dry......
I agree with the guys, for all out bashing or just beating around, I like a
thicker oil in the diffs. It puts more power to the ground and is alot more fun.
pinion
I would say no, if they are shimmed too tight they make some more noise then normal.
or if there slipping(too loose)
A clicking noise useally means missing tooth on one of the gears.
