Clutch shoes for savage 4.6
THE PIPER
TIME TO PAY THE PIPER
Brantford Ontario Canada
Hi guys in regards to clutch shoes how will I know when they need replacing? What is there life span?I'm reading about the Nova shoes and they look great. Anyone used them on there savage. Oh and where can I get a clutch shoe tool? Cheers!!:cheers:
hey i know wot its like i have 2 replace mine and there are so many options i guess its wot u use it 4
i know dat if ur racing u have a different setup to wen ur bashing dats y i like da stock shoes but they wear out quick
i have bin looking at these
Flywheel And Shoes
also crash will love this coz he supports NITRONUTZZ heaps also crash do u know if members of HPISF get a discount
10 % discount
Flywheel And Shoes
Yes indeed, hpisf members get 10 % OFF
EMAIL ROB WITH WHAT YOU WANT BEFORE BUYING OFF HIS EBAYSTORE, HE WILL GIVE YOU DISCOUNTED PRICE.
W/ the stock Teflon shoes I would inspect them after a hard bash session .. only b/c (like my Real cars) I like the engine spotless.. I would take some sandpaper and scuff the shoes up so the grab harder. W/ the stock shoes expect like 3 gallons of life out of them .. (depending on what gear ratio your using)
I love my nova shoes (w/ mugen 1.0 springs) read my review https://www.hpisavageforum.com/forums/showthread.php?t=3319
expect like 3 gallons of life out of them also ..
Wow 3 gallons is the most i should expect out of clutch shoes?
I think I was at gallon #10 before I replaced them on the savage 25......
anyways I love the HPI aluminum shoes....
heck with the teflon shoes
Flywheel And Shoes
I hate bashing on vendors and stuff but I had two buds that put that exact setup on their savages and the shoes went very fast, I wanna say like a half gallon. I would stick with stock before running those. I had good luck with hpi shoes but kinda pricey. Buy the nova shoes best bang for the buck!
I've run the HPI teflon shoes for both my mills. I tried the Nova shoes and somehow managed to tear them up in under a half gallon so I went back to the HPI shoes.
I run the 4.6 X stock shoes with the mugen 1.0 springs. I need more idle for other reasons, and it works great. Spools up alittle before take off! Don't know if I would recomend it on a normal 4.6.
Mugen shoes with 1mm springs. Very good set up. You will need to maintenance the alum more, then the teflon
You gotta use a really heavy spring .. like mugen 1.0 springs or you will toast your alloy shoes
I was using the mugen 1.0 springs and the mugen pilot nut, like in the review. I think I was just unlucky.
