Tip for a cooler engine
Yokomo99
New Member
I have a little mod that I do that helps transfer heat from the head button to the cooling fins. Just add a thin smear of heat sink compound on the top of the head button before bolting the fins on. This will increase the rate of heat transfer between the two parts. I use Arctic Silver paste but any heat sink compound will do.
Matt
dunno why no one's ever thought of it before...works for heat sensitive PC's...should work for our little Nitro mills too...nice idea!
I like his idea better ... Thanks Yokomo99 .. cheap and easything to try out .. How much of a temp drop have you noticed ?
Hi,
welcome to the forum!! I just used some heat sink compound around the temp sensor for my radio so it would give me better readings (closer to what I get on the IR gun), never thought of using it for that though.
thanks
Heat sink compound works great, I use it on electronics daily. It's just a pain in the butt if you have to clean it off anything.
