Carb upgrade question
Leshill
Hi All,
Savage 25 with .25 engine and the original carb as per factory. Carb rotates even when screw is tightened. On inspection, I can see indent in carb body meaning over tightening as occurred. I have a Picco .26 engine with carb. The carb fits perfectly into the .25 engine. Linkage all works fine. Question is, will the Picco carb work on the HPI engine?
I've never tried it, but if both carb necks have the same external dimensions, I don't see any reason why it would not work. My biggest concern would then be the possibility of o-rings having dried out and creating air leaks. Having said that, I have a couple of 20-year-old Picco .26's that have zero issues.
What is the condition of the Picco .26 engine?
Is it well used and not running or is it a runner?
Does it have good compression?
If it's a good engine, I would swap out the HPI and replace it with the Picco.
The Picco is the superior engine of the two.
Picco is hands down a better engine. But 10 years ago when the sun shone nice and bright, the grass was always green and Picco made big block nitro engines, I experienced carb problems with two of my Picco 28 engines had to replace them with HPI carbs I had lying around. As Ohsnap said, if the carb neck fits in the crankcase, there should be no problem.
Picco engine has a button problem but other than that it’s good. If I could find another button for it I’d put the .26 Picco engine in the Savage.
Yep it fits nice and tight but I didn’t want to just crank it up in case I did damage to the HPI engine.
