Has anyone used these before, concerned about using Aluminum gears in trans.
Hot Racing HPI Savage 25 SS 4.6 Aluminum 2 Speed Transmission Gear Set SAV1000H
Was the HOT Racing gear that stripped the same one as the original that previously stripped ??I was having issues with my transmission stripping the original factory gear in my savy so installed these to try to make my truck more durable. On the first run I had issues with one of the gears stripping . I’m not sure if the gears were bad or I installed something incorrectly.
Honestly I had so many issue with the tranny I kinda got frustrated with it and put it on the back burn and never opened it up to see exactly what broke in the tranny.Was the HOT Racing gear that stripped the same one as the original that previously stripped ??
And did you find the reason behind stripping gears ??
WOW $ 88.00 + FOR TITANIUM and you still get two "plastic" gears . To rich for me, thanks for the heads up though.They also make titanium gears but there a little more expensive. https://m.ebay.com/itm/Hot-Racing-T...rin-2-Speed-Gear-Set-/122146916872?nav=SEARCH
Well, thanks for your imputHonestly I had so many issue with the tranny I kinda got frustrated with it and put it on the back burn and never opened it up to see exactly what broke in the tranny.
Not into Facebook, any other way to contact??Guy on the Facebook page is making sets of stainless gears for $40 for a 2 speed and $35 for a 3 speed.
Also sure it is'nt $40 for 3 speed and $35 for 2 speed.
Thanks , appreciate it.Yes I'm positive, I'll see if I can get his info for you.
