Rubenator80
I'm not 100% sure what engine that is, but I do know, that is probably one of the loudest pipes I've ever heard. Lots of low end torque, but damn loud, so prepare for that. The engine looks like the nitrostar 25: http://www.hpiracing.com/en/part/1406, which means it's either an alternate engine on a 21 savage (original), or is a later version of the original savage that should have the 4 spider gear diffs. Pretty sure the .25 savage and on had 4 spider diffs to help with durability.
The HPI polished pipe isn't quite as loud and performs really well, can usually find one on ebay for cheap. I like the Losi HT (LST2/XL pipe), but it takes a bit of work to make it fit since it doesn't use a coupler. It's quieter, but makes for a nice power delivery on the 4 or 5 engines I've run it with. Requires a bit of grinding so you can use a coupler like you have there.
quite a few parts
Quite a few???
Just my idea, i can't think of a lot of parts that won't fit a pre-X Savage.When you say quite a few. Can you please be more specific. Thank you.
I stick with my guess that it is a Savage 21 RTR. Assuming the red shocks, TVPs and radio box are stock. It does appear though that upgrades have occurred. That HPI ribbed pipe is an "upgrade" and someone swapped the engine for an HPI F4.1.
?????? the body is a Savage X body..based on the body I'm gonna say 21
I say it is an SS http://www.hpiracing.com/en/kit/845
Red springs, ribbed tuned pipe.. And an S25 engine.
The 21RTR had blue TVP's IIRC
Copied from HPI's site.
Savage X parts that will fit on past Savage trucks:
Nylon Roll Hoop (more durable)
Nylon Rollcage (engine protection)
Warlock Wheels* (stronger 17mm hex hub)
17mm Hex Hubs (stronger)
GT-2 Tires (lighter)
Turnbuckles (easier to adjust) Transmission Case (easier to remove)
Differential Housings* (front and rear)(easier to remove)
Shock Towers (additional shock locations)
Suspension Arms (lighter)
Radio Box (easier access)
Slipper Clutch (dual pads plus rubber dampening)
Savage X Chassis Plates* (lowered CG)
F4.1 Engine
* May require a few extra parts for conversion
Parts carried over from past Savage trucks:
Internal Differentials
Internal Transmission
Dogbones
Driveshafts
Brake
Axles
Exhaust
Uprights
C Hubs
Body Posts
Body Position
Engine Mount & Plate
Servo Saver
Shocks and Springs
Past Savage parts that will NOT fit on the Savage X:
Alloy Roll Hoop
Spur Gears (hardened steel gears will fit with new inner hub)
Polycarbonate Receiver Cover
If i wanted upgrade to a better or different engine. Do you have any recommendations and that will fit my truck and also the pipe. I would like a quieter pipe. Thank you
Not exactly "Quite a few" as you stated before...
