Octane spares?
F-Type
Gothenburg - Center of the Universe
Hi
Can I use any chassis and gear spares from the Savage XL on the Octane?
What about flux spares, any of those that can be used? Specifically found a diff gear housing for the Flux that I was wondering if it would fit the Octane.
Thanks, Thomas
I need to look at a manual to be sure. But I believe the XL, flux and octane use alot of the same chassis components (save for the obvious stuff that would be exclusive to certain vehicles).
Are you referring to the HPI86827 diff case? If so then yes, this is the same case as the Savage 4.6, Savage XL, and Savage Flux which means if you found another that's listed to fit a Flux then it should fix your Savage Octane just fine as well.
