Post your tire and rim setup pics
Proline Moabs on Axial Beadlocks
How well do those Kysho's dig? Looks like a great tire
Panther Python's on Kyosho wheels
those moabs look rad
Kysho Tires
Super Losie bolt ons and proline 40 series
Proline mashers 40 series
another set of mulchers that arnt 40 series
I'm not sure i sold them before I had a chance to try them out. They had some dry rot on them. they were hard compound tires
got some new wheels
ofna pirate wheels
rc4wd pulling tires
Proline Mulchers on RPM 1/2 offset revolver wheels...
Cool thing about these are I can run them on any of my nitro rigs because they all use 17mm hexes to mount....
Sometime soon I will have to see what these RedCat 3.8 3/4 offsets with Losi Super Bolton's look like on the Savage
, They do work well and setoff the look of my XTM MMT Truck...
Tamiya DV Lug tires mounted on RPM 17mm hex wheels with 1/2 offset.....
These seem to dwarf the stock Savage X 4.6 tires and wheels....
I will glue em down with my customary Plumbers Goop to keep em from flying off the wheels :D
Here is a couple shots of them mounted on the Savage....
My son has a set of Big Joes in his LST rig, they have way too much side bite for my tastes, his rig flips over all the time with them mounted on it......
Mine does the same thing when I'm running it on asphalt or cement road. But on grass or dirt it grabs really good for me and it doesn't flip at all. I am also thinking of trencher 3.8
image.jpg image.jpg Hey guys. Just a little update about my proline big joe 3.8. After installing sway bars I had better traction and way lesser flips if not any.
View attachment 1165 View attachment 1166 Hey guys. Just a little update about my proline big joe 3.8. After installing sway bars I had better traction and way lesser flips if not any.
while sway bars will work decent on smoother surfaces, they will limit suspension travel off of most jumps and rough ground and cause more problems that they are worth..... so if you have big air in mind I would recommend removing them or at least disconnecting them for this type of antics....
I don't do any jumps at all, and I run it mostly on parks. So maybe that is why it works for me? But that is definitely something to think about. Thanks Jam Racing 1
I love my sway bar set up as well. helps me powers slide in the grass at full throttle with no roll overs. But I also do not jump my truck, it's only a backyard basher.
What are the white ones called jam?? Redcat?
Proline 3.8 Trencher X on 1/2" offset desparados
No idea what the rims are but I am sure that the tyres are DirtBonz (if you look very closely, you might see it written on the sides!!!)
Traxxas 3.8" split spoke 17mm and traxxas T-Maxx 3.3 tires:
Traxxas 3.8" Geode 17mm and traxxas T-Maxx 3.3 tires:
Traxxas 3.8" Geode 17mm and traxxas chevron tires:
I like the second ones for winter since the rubber is a bit softer compound, but I really like the chevrons for summer since I run on concrete and grass 99% of the time and they don't have a ton of side bite.
Or XL 5.9 With axial bead Locks and Losi 420 Road Rash tires20151202_190900.jpg 20151202_190828.jpg 20151202_190847.jpg
