thryou can use the flywheel from your old engine, far as clutch I recommend using an alloy set of shoes and medium springs for it... you can find this stuff at RC Planet or A Main Hobbies... as for a glow plug I would follow what the mfgr of the engine recommends to use, but usually a medium plug will work well with 20% nitro...
http://www.rcplanet.com/HPI_Aluminum_Clutch_Shoe_Set_3_Piece_p/hpi87196.htm
the flywheel on my old engine is stuck and cannot be removed so should I just buy a stock one or is there a better oneyou can use the flywheel from your old engine, far as clutch I recommend using an alloy set of shoes and medium springs for it... you can find this stuff at RC Planet or A Main Hobbies... as for a glow plug I would follow what the mfgr of the engine recommends to use, but usually a medium plug will work well with 20% nitro...
thr
what brand glowplug should I buy and what type specificly
Most all engine manufacturers include some recommendation on what plug will work best for their particular engine.....
As you seem by your posts to be quite new at the nitro side of things I would follow their directions so you get the most satisfaction from your new engine......
will the hpi ones work
