With that engine you should be able to wheelie no problem. A good tune and the right spur/clutch bell combination is key. I've always had good luck with a 16/48 gear combo.
I also have a 3 speed transmission that I have not installed yet how should I go about tuning it? I'm sorry for the stupid questions I just want to learn
On the last page they show adjustment for the 3rd gear. To adjust 2nd you need to open the transmission and remove the top gear shaft/gears. This gives you access to the middle shaft/gears. If you look on page 4 you will see where the clutches are.
