fuel leak
stuarth
Hi guys i have fuel leaking from 1 of my adjustment screws on carb when i try to prime up engine , tried posting up picture to show which 1 but cant get it up loaded , its down near exhaust on base of carb above it is long thin adjustment with black plastic ?? Any help be great
the one with the brass sheath in this pic?
if indeed it is the point of your leak, use an 8mm open end wrench and simply tighten it down, if the leak persists then take it all off and use a bit of sealant on the 2 small washers and under the threaded flange that screws into the carb base...
This! As Jam says just use a bit, don't need to go crazy on the sealant as you don't want it to end up in the carb and plugging things up.
Thanks for help guys it is actually the screw going in horizontal thats the problem
