this last summer had alot of wet grass and I got addicted to wd-40 .loctite or CA would come loose so I started cleaning the scew and its seat with carb cleaner and all is good
first post , how did I do
Do you do tighten them up good with a decent hex wrench? Its suprising how much extra torque you can get on them grub screws with wrench that wont slip.
when you use locktite there is no need to wrench the screws down as tight as you can. I usually put on the loctite and tighten the screw with moderate power until it stops...the end. never had any issues
not too bad but wd-40 doesnt help keeps screws tight lol
