traxxas ez start on ofna force and HPI engines
adb140275
aka Ebee
this mod will work onall ofna force engines, HPI G series, F series, and K series (axial) if you make an adaptor from an 11mm socket
can you show more pics of how this works? back of mill? take off the cover and show how the motor act turns the con-rod? where the 11mm socket comes into play?
I'm not going to rip my ez start apart, but ill show you the back of the engine and where the socket would come in. if you know the shape of a traxxas OWB you will know what to do with the socket. the traxxas bearing fits the force engines though
What are you using for a power supply? that motor must suck some juice turning over a .28 instead of a .20. I had a set up that could start my truck without even touching it back in the day, it was only a .18 but it still blew peeps minds lmao.
regular 7.2 volt battery like what traxxas normally uses. and why? well the header melted 2 pullstarts, and theres no roto start access. i don't want to buy a bump box. just an experiment, ill keep it if it works out
yea 3rd channel would be funny. but I don't even like to carry around my lil hot shot. so much for that HUGE start system
