NITROMITE
- Location
- Pataskala,Ohio
its a shim issue you need to re shim the diffs thats why its binding
i dident shim the diff @ all their is very little play as it islooking at the vid something is wrong wit the front diff. sounds like the pinion is gone for that matter. we all know its not. Did you shim the pinion in be you put the diff over to it ?
Are the bearings good? No one has mentioned those yet. Based on what I hear in the vid, and everytime I have that same problem, it sounds like either the ring gear is too tight on the pinion, or your pinion is binding somewhere (check those bearings also). Take it apart, look everything over, make sure the diff bearings are seating in the bulk correctly and nothing looks like it is rubbing.
