I would like to know this as well as I have been looking at the same servos. When someone answers maybe they can help out with the torque rating on the HPI SF-5 versus the hs-7955tg? Not to hi-jack but I seem to be having trouble finding how much torque the HPI servos put out versus the aftermarkets.
Here are some sf-5 specs i found after googleing it, not sure how accurate they are as it came from another forum.
SPECS: Length: 2.15" 54.5mm
Width: 0.79" 20mm
Height: 1.5" 38.1mm
Weight: 1.64oz 46.5g
Voltage: 4V-6V
Torque: 314 oz/in 8.9kg/cm
Speed: .20 sec/60 degree (6.0V)
And the 7955tg
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-68F to +140F)
Operating Speed (4.8V): 0.19 sec/60° at no load
Operating Speed (6.0V): 0.15 sec/60° at no load
Stall Torque (4.8V): 250oz/in. (18kg.cm)
Stall Torque (6.0V): 333oz/in. (24kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Current Drain (4.8V): 200mA/idle and 2.0 amps at lock/stall
Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall
Dead Band Width: 2usec
Motor Type: Coreless Carbon Brush
Potentiometer Drive: 6 Slider Indirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: Titanium Gears
Connector Wire Length: 7" (178mm)
Dimensions: 1.57" x 0.78"x 1.45" (40 x 20 x 37mm)
Weight: 2.29oz (65g)
The 7955 is also coreless and digital which i don't think the sf-5 is either, i don't know? also the hitec is full titanium geared i believe and has 24kg of torque over the sf-2's 8.9, tho the sf-5 is less than half the price on ebay.
I ran the hitec 5985mg servo for steering and the 5645mg for throttle/brake on my stock radio system for about a month without any problems before switching to a dx3s
Cheers man, I'm running the 645mg as my steer servo now, its ok but my sf-2 throttle servo is getting really weak now and struggles to open the carb with a throttle return spring fitted, so instead of buying a new throttle servo il upgrade my steer servo and use the 645mg for ny throttle/break.
Just didnt wana splash out to discover it wont work properly with the hpi radio gear, which will be replaced too, but in time.
