Zane's Mid tank build
Looking good man!! I'm digging the paint as well!
Not sure if it's the angle of the pic, but you might want to turn up on the handle of the carb that your linkage hooks up to. But like I said might be the angle of the pic.
Good looking Savage!
rctruck
It seems good to me.. But do you think it would be better if I rotated it up?
And thanks for the compliments guys :beer:
In the pic you posted it looks fine, just make sure that the servo is pulling the carb straight out instead of an angle so you don't damage the carb.
I was referring to this pic---VVVVV
Might be the angle of the pic, but just seemed like the throttle side of the servo horn is sloped down. You would have a better perspective than me, as long as it all operates smoothly and the linkage doesn't pop off the carb you should be fine 🙂
Well.. I went to change the gearing today and ran into a problem..
When I line the mounts with the mounting holes in the plate the CB rubs on the spur. Is there anything I can do about this or do I need to buy a different CB? The weird thing is that this is the stock CB, and according to people this OFNA .28 is the same as the stock engine.. Apparently not.
take out the mill, take off the clutchbell and shoot a pic. lets see what's causing it to sit so far off the flywheel.
Thanks for educating my noobness :grouphug:
I didn't know that mattered.. 😢
