OK guys, got one for you. There is a couple of trucks on the track that have the same problem. They start right up when they are cold, get them tuned in perfect, running between 220-240 temps. The low side is perfect on the pinch test. The trucks run awesome for about say 10 to 15 minutes then its like they cut off on idle for no apparent reason. When you go to start them back they wont hit a lick. If you let them cool off they fire right up and will do the same thing again. Any ideas?
