Will these fit?????
FINCH
Are ALL the shocks interchangeable for the savage. IE: The xl will fit on a 21, flux, x, ss and all those combinations. I have a 21 and want to replace them but i see a lot on Ebay from XL and such. Will they fit?
Yes the 21-25-x-xl shocks are the same.
The Flux shocks are plastic big bores which will allow you to run one on each corner instead of two. If you use these on the pre x arms you will need a washers on both sides of the shock (mount to the outside of the arm), because the x arms the shocks mount in the arm.
Glad I could help!
If you do decide to get the Flux big bores, you might also need some Hellfire shock standoffs for the top depending on if they come with all the hardware.
Here is a pic of the Hellfire standoffs
Here is what comes stock with the Alum Big Bores
For more info on the hellfire standoffs hit Sunk thread on the Hellfire standoffs
Or do like Hyp and run down to Ace Hardware for something like this-->>Hyp's standoffs
Hpisf staff-- any way we can lock sunk's thread with the pics? I find myself comming back to it quite often.. Thanks
U knpw what, i have read a few posts on the subject and i think i will just keep with the factory ones, or atleast plastic ones. I think the alum ones would be too tough and break my ole 21. But the big bores look cool. I want a front and read alum shock tower mount so i can drop it nice and low for parking lots and raise it high for bashing. Can i get one for the 21?
I'm not sure if they still make any for the 21/25 bulks, you might want to get ahold of hypnotiq (the pics with the Ace standoffs from above).
I've never tried alum shock towers, just prefer the plastic towers so if I have a really bad landing it will flex instead of bending or possibly ripping off the bulkhead.
You don't have to have the suspension maxed out for bashing. Watch this video of Bankrupter's--http://www.youtube.com/watch?v=r9g_4gEyw0s
And that with this setup
here is the original link-->>Bank's jump thread
You might want to start a new thread on the Alum shock towers, might get some better responces.
Good luck bud 🙂
