When did Sav diffs change?
leslie
hollis, nh
Hi all,
I pulled apart a new diff that I purchased. I bought the whole diff, new for 20.00. I noticed that the new diffs are different than my original diffs.
The new diffs use part number 86032a, b, and c for the internal bevel gearing. The older diffs use 87193 and 87194. The new diff has 2 small bevel gears, the old style has 4 small bevel gears.
I mangled the new one. I'm wondering why they changed, the old style seems stronger.
any thoughts?
Cheers
Leslie
hello.... hmmmm you sure the ones you just got are a new style? the new x style are 4 gears well actualy 6 bevel gears inside 4 small then 2 outdrive gears.. the savy 25 original difs are the 2 gear set up... then they went to 4 bevel gears before the x style came out ... now they all have 4 gears.....hope this helps you out a lil...
Interesting. My SavX diffs had the 4 small bevels and the 2 large. The ones I bought recently had the (apparently) old style. This might be why they were only 19.99 for the whole diff assembly. I guess you get what you pay for. The old style did not hold up very well.
