What gears are you using
X25
it's all good
Franklin In
Just figured it would be nice to know what setup every one is using. What spur gear and clutch bell are you running? Also it would be a good idea to add what mill you have and if you are running stock size tire or 40 series. Might also want to say if you use your savy to bash or race. Also let everyone know how you like the gears that you run please.
Racer=Axial .28, Nubz tires, 16/49, 2 speed transmission
Basher=Axial .28, Stock X tires, 17/49, 3 speed transmission
savage xss .. stock savage 25 tires on rpm monster claws wheels, stock k 4.6 engine, running my stock gearing (18 tooth bell i think and metal 47 tooth spur) great for bashing.. and wheelies
savage x wheels and tires, axial 28 rr spec 1 , 52/15
2 speed trans.
15/49 with a 2-speed (although I'm in the market for a 3-speed), running a very tired motor (probably putting out about the same as a .18)...lol
I'm running a 15/52 on my savage x 4.1. it is a 2 speed but still am having tranny troubles with no shift. whats everyones opinions on the 52tooth gear. should i go lower or is the 52 ok?
