picked up most the stuf i needed. belray foam filter oil, losi shock oil, ARO, and some nitro cleaner. I noticed this stuff called Gunk Dry Graphite spray at local automotive store. This company has quite a few products out and look pretty affordable. I was curious if anyone can give me some info on what they think about these two products.
BGS1 - Gunk Dry Graphite
Use as a lubricant and parting compound on engines, pumps, business machines, etc, wherever heat and friction are a problem.
Contains no oils or moisture-based diluents: is inert to water, oils and alkalis.
Effective from -37° C to +537° C.
and
L616C - White Lithium Grease
Reduces friction between metal to metal or metal to plastic applications. Use on hinges, locks, doorstop latches and striker plates, speedometer cables, brake cables, distributor cams, battery terminals, etc. Aerosol sprays on as a liquid, and then sets up as lubricating grease that will not melt, run, wash off or freeze. Protects against rust and corrosion.
I'm just curious if any of the above products can help me, and if they can where would be the best to apply them, or am I just wasting my money. Any info would be much appreciated.
Here the link if you want to check out the products.
http://www.gunk.ca/products/automotive/lubricantspenetrants.html
