What beadlocks are these?
Fx
Could someone give me the link to them as well please? Thanks guys.
Yes those ones, do they have them in a zero offset.
FX- The wheel you showed from Maximzerbead is called the X-75 ( only in 14 hex ) and only comes in 3/4 off set. I have the alum ones. Been thinking of getting those for racing with on the track. I like the off set.
Maximzer bead 3/4 off set
The other wheel comes in 1/2 and zero off set ( 14 and 17mm hex ). These rea real nice in 1/2 off
Maximzer other option 0 and 1/2 off set
Now: SMF wheel section
You need at least a 1/2 off set for a Savage even the 3/4 is good. I have the 0 off set in alum used them for a trailer and that alone.
make sure you either want the 14 or 17mm hex for the setup then look at the offset
Thanks hop, I will most likely get the X-75's. I think I know what tire I'm getting too.:jumpers:
I would recommend the X-75's with the Losi Zombie Maxx Tires. I've seen this combo before and it just looks SICK!! Not to mention the Zombie's hook up very well.
