I could be wrong, but as long as the transmission was put together correctly and you did not mess with the adjustment screws wile they were out, the shift points should not change. As far as a factory setting...don't know about that
the default settings are in the manual, the XSS manual has default for the 4.6k. when you start to make the adjustments the screw has to be flush
heres a snapshot from the XSS manual
