Transmission Rebuild Question on Shift Points
Shanty
I WILL BREAK IT!!!
Hey,
I recently had to take apart the transmission and put it back together. My question is, will my shift points be all messed up. And if so, is there anyway to put them back to factory like say the carb needle settings.
Thanks
Shawn Stevenson
I could be wrong, but as long as the transmission was put together correctly and you did not mess with the adjustment screws wile they were out, the shift points should not change. As far as a factory setting...don't know about that
the default settings are in the manual, the XSS manual has default for the 4.6k. when you start to make the adjustments the screw has to be flush
heres a snapshot from the XSS manual
I did not touch the screws when they were out. All I did was pull the gears out and then put them back in the way they are supposed to go according the the manual. And thanks for the picture LOL Shiftpoint
