tire are these big joes on prolines
cougar390
will the proline wabash hook up to my 4.6 rtr stock stock are do i need the offset kit. Also what excatly does the offset kit do.And last should i go with the big joes or the proline MOAB .I like how yhe big joes look but everybody says there really heavy. I wonder what sized engine could make the savage wheelie with the big joes on it .
If you get Wabash wheels with 17mm hexes, they'll bolt right on. IDK what you mean exactly by "offset kit" (hub extenders?), but 40 series wheels will stick out a tiny bit farther than 1/2" offset Maxx-sized wheels as it is, so no other parts should be needed. I don't run either of those tires, but I know Moabs are about as heavy a tire as you can get. Hope this helps!
