throttle spring
It might affect it a little with the weak stock servo. But if your gears strip in the servo or the linkage for the carb come un-hooked you will be wishing you had a spring. I wouldn't ever run without one personally.
I always use it. I had a scare the other day when it cam unhooked while driving. just the tension from the rubber boot is enough to open the throttle enough to make it difficult to stop
ya i wouldnt EVER run without one as the first time u do you will be kicking yourself in the butt when you smash it into a tree lol
