88gtanotchback
SAVAHOLIC
Hey guys its a great day to waken up by the post man.
Freshly unveiled
http://memimage.cardomain.com/ride_images/1/1339
/4261/3347130194_large.jpg
quick test fit.
so what I'm going to do is
1) notch and flip the battery boxes, so the deans fits thru better as well as easier to get to the batteries
2) red loctite the pinion
3) Tighten Slipper right down (no play needed from what i understand)
4) Rig up Velcro for the boxes (on its way from TCS)
5) Install Cen diffs
6) Install TCS 5mm Chassis (on its way from TCS)
7) Install HPI Big Bore Aluminum Shock (on its way TCS)
8) Install HPI HD DRIVE GEAR 18-23 TOOTH (on its way TCS)
9) install wheelie bar
10) charge Lipos and smile ear to ear
After that I'm hoping everything will be good and ready to rock. Just hoping my Speky gets back soon so i can use that for it if not i guess the stocker will have to do. Any other tips you think i should do?
now for questions
1) I'm missing is the castle link that i got to ordered yet. Is it safe to run it without or do i need to set my LVC?
2) when i move the truck back and forth theres alot of noise between the pinion and spur. is this common or is something not right?
3) the bullet connector appear to be right in the way of the body. whats the fix? just reroute or shorten?
Freshly unveiled
quick test fit.
now for questions
