Strange Glitch
stevage
PA
Whenever i start my truck up,the servos start twiching like crazy and it makes it worse whenever i go on the throttle.My truck took off on me because of that.It only does that when i have my truck started. WHATS WRONG!!!!!!!!!!!!!!!!!
Sounds like you have some metal on metal contact somewhere, check to make sure that you crystals are clean and are in all the way and make sure none of you wires is touching metal or are pinched.
did you ever get your servos wet ? make sure your reciver wire isn't frayed or anything ... change your crystals that most likely will slove the problem
I had a problem with my receivers glitching at close range with a spektrum dx3.0. I sent them back. Is it anything to do with your transmitter being too close. is the glow igniter still attached when it is glitching?
