steering ?
Yes it worked. A little small but you guys get the picture. You see the two plastic pieces over the spring??? thats whats binding a little. Kinda gets stuck when I turn the wheels all the way in one direction. Going from left to right she gets stuck but from right to left everything is smooth.
I don't think you will need that spring unless you upgrade your steering servo. If I'm correct that spring is for higher torque servos. I think the reason for getting that spring is it will help protect the servo from a crash to the front wheels.
I fixed the problem. Just needed a little shimming between the bearings and the battery case.
