Steering
bigbazz08
perth western australia
i was wondering if blue bird bms-617mg+hs super fast metal gear servo would be to much the throttle/brake is still the standard set up it was used as steering but decided to upgrade to a better one for steering cornfused
can you list the specs or link us to it bro?
Here's some spec's that I found for it.
Weight: 45 g
Dimensions: 40.5 x 20 x 37 mm
Torque at 4,8V: 7,6 kg/cm
Torque at 6,0V: N/A
Speed at 4,8V: 0.09 sec / 60 deg at no load
Speed at 6,0V: N/A
Ball bearing: Dual
Metal gears: Yes
BMS-617MG+HS Super Fast Servo (Mos-FET). Servo designed for racing, due to racing tough competition make servo hot even over use, the upgrade assist parts are heat sink settle down motor overuse. With a servo accessory package and is made with a heavy duty servo case, the servo is designed for R/C high performance Car applications. Double ball bearing with flexible rubber waterproof, otherwise the output spline is same with Futaba 25 tooth.
Features:
- Metal gear
- curve gear with smooth.
- Double M9.6 ball bearing (si-oil)
- 3 pole strong torque of motor with low signal affect and success get CE certification.
- Rubber fitting case for waterproof
- Same with Futaba 25 tooth spline
- Heavy duty servo case
- middle of heat sink
