Spur question
Dooley
ERCM Pipe #29
Middletown, Indiana
I feel like I am missing something.
I have the pin>hub>plate>pad>spur>spring>washer>nut
No matter how tight I tighen it all down it slips so bad that it wont even roll.
isn't there supposed to be another plate b4 the spring?
Yep Shakes, there is a small metal spacer that presses into the spur gear then the washer with the hex cut-out goes over that, then the spring, then the nut. Good thing to check because it is an easy piece to forget when you are swappin' gears.
i was looking at the hex'd washer and noticed it was rounded out. the spur I'm running now is a RRP and came with a bearing to put in rather than using a bushing.
Ill get some new hex washers and pray thats all it was 🙂
thanks for the info guys.
