Some Glow Plug Info
kvnnets
Oakville, Ontario, Canada
The technology of glow plugs escapes most of us. Sure, we all know that our nitro engines need them to start and to run, but beyond that, we don't know much. Glow plugs are, in fact, a critical part of the whole performance picture. To help shed some light on the technology of glow plugs and for some practical information concerning their use, I consuited a few of the most knowledgeable people in the industry.
The roster of experts who lent their knowledge to this piece includes Howard McCoy of McCoy Racing, Jerry Conley of Wildcat Fuels and Alberto Picco of Picco Mfg. They all have extensive knowledge of glow plugs.
WHAT IS A GLOW PLUG?
A glow plug is the ignition system for your nitro-powered RC vehicle. Instead of a spark-ignition system such as those found in automobile engines, the remarkably simple glow plug is what we use to ignite the fuel in our engines. It doesn't have a single moving part or adjustment; its only functioning component is a simple, stationary coil of wire.
HOW DOES IT WORK?
Starting an engine is one of the functions of a glow plug. When a glow igniter is attached to a glow plug, it causes the glow plug's coil to "glow" white-hot. This ignites the air/fuel mixture in the cylinder when the engine is started. Once the engine is running, the heat generated during compression and combustion keeps the glow plug's element hot enough to continue igniting the fuel mixture on its own without the help of an external power source. In the simplest terms possible, that's how a glow plug works.
WHAT IS A TURBO PLUG?
Glow plugs are available in two configurations: standard and turbo. Most engines come with a standard plug. They feature a straight, threaded housing that threads through the cylinder head into the combustion chamber. Turbo plugs feature a different type of housing; the end that goes into the combustion chamber is tapered. The tapered end mates with a head that is specially designed for use with turbo plugs. The head is also tapered to accept this type of plug. The supposed advantages are less compression leakage around the glow plug and less disruption of the combustion chamber. The hole in the cylinder head that exposes the glow plug to the air/fuel mixture in the cylinder is much smaller, and there are fewer rough edges to create unwanted hot spots.
WHICH TYPE OF GLOW PLUG SHOULD I USE? OK; you've blown the glow plug that was included with your engine, so it's time to get a new one. Which one do you buy? You could try to find the same plug, if information about its brand and type was included with your engine. More likely, you will have to choose from the brands and types of plugs that are available at your local hobby shop.
What makes the subject of choosing a glow plug a little confusing is the variety of types that are available. Each manufacturer offers a range of plugs, from as few as three or four up to 10 or more. A plug is usually identified by a code that indicates its effective operating temperature; not the operating temperature of the engine or the outside air, but the relative temperature of the glow plug's coil. Each manufacturer has its own unique temperature-rating system, and general application recommendations are sometimes included to try to steer consumers toward the correct plugs for their needs. The process can be confusing, however, because a universal rating system does not exist for glow plugs. For example, an O.S. R5 plug is not the same as a McCoy MC-9, although both are considered "cold" plugs. A glow-plug manufacturer's guidelines will suffice for average enthusiasts who simply want their boats to run; racers and performance buffs, however, won't get the most out of their engines without a little experimentation. So what should you look for in a replacement plug?
Some general rules about plugs are determined by the size of the engine and the type of fuel used. Smaller engines usually require hotter plugs, while larger engines favor cooler plugs. Engines that run fuel containing a high percentage of nitro favor the cooler plugs as well, while those that run on less nitro prefer hotter plugs (nitro fuels for car engines typically include 10 to 40 percent nitromethane). For example, a small, .12ci (2.1cc) engine that burns highnitro fuel would favor a warm plug in a mid-range temperature (small engine = hotter plug; high-nitro fuel = colder plug). The same plug might also be suitable for a .21ci (3.5cc) engine running low-nitro fuel (large engine = colder plug; lownitro fuel = hotter plug).
The size of your engine and the type of fuel are easy enough to determine, so these guidelines should get you pointed in the right direction. For racing buffs who want to get maximum ponies, however, another element that's not easily determined-yet should be taken into consideration-is compression ratio. The compression ratio of an engine will also be a factor in choosing the proper plug. High-compression engines favor colder plugs, while those with lower compression favor hotter plugs. Engine manufacturers rarely disclose an engine's compression ratio, so it may be difficult to use this information to select plugs unless you know how to calculate compression or can measure it with a compression gauge.
This information is best used when adding or removing head shims. More or thicker shims lower the compression; fewer or thinner shims raise it. Remember: when adjusting head clearances with shims, a plug change may be necessary (this should be left to experienced engine tuners).
WHAT HAPPENS IF I USE THE WRONG PLUG?
If you have used a plug that is too hot or too cold for your application, this will be revealed in one of two ways. If the plug is too hot, the engine may suffer from detonation, pre-ignition and high running temperatures. Detonation occurs when the fuel mixture explodes quickly rather than burns. You don't want this to happen because it can damage the engine. The telltale signs of detonation are a "miss" in the exhaust tone at high speeds and a pitting of the cylinder head around the glow plug and the top of the piston. Severe detonation can cause the coil element of the glow plug to come loose, and this can severely damage the engine. The primary cause of detonation, however, is excessive compression. Simply using a hot plug will not usually cause detonation, so don't be afraid to experiment. If you're using high-nitro fuel and have increased the compression by reducing head clearance, however, a hotter plug may just push the engine too far and cause damage. At the very least, an excessively hot plug will cause pre-ignition, in which the fuel mixture begins burning well before the piston reaches the top of the cylinder.
Using a plug that is too cold will result in a loss of acceleration and top speed and will cause poor engine idle. If the plug is much colder than it should be, you might notice an excessive raw-fuel discharge from the exhaust pipe, but don't confuse this with an excessively rich fuel mixture.
WHAT MAKES A GLOW PLUG HOTTER OR COLDER?
Many elements influence a glow plug's temperature range, but primary is the thickness, length and composition of the wire used to form the coil. It will be impossible to find out anything about the composition of the wire because most manufacturers keep it a secret, but the wire can certainly be measured. Other factors that affect a glow plug's temperature include the size of the hole in which the wire is installed, the type of plating used on the glow-plug housing and the material the glow plug's housing is made of.
The best way to keep track of your glow plugs is to store them in their original packaging; the plug type is printed right on it. A visual inspection won't help you much, since some plugs don't have any temperature information printed on them; that's why the original packaging comes in handy.
IS ONE TYPE OF PLUG MORE DURABLE THAN ANOTHER?
If the fuel mixture is properly adjusted, most plugs should last equally long. When the fuel mixture is on the lean side, the hotter plugs tend to be more susceptible to damage as a result of their typically thinner elements. The quality and consistency of the material within the glow plug's element can also affect durability, and this varies among manufacturers but can be sorted out with experience. So, yes; within the various brands, there are slight advantages to colder plugs, but these advantages are not enough to justify choosing them if the result is diminished performance.
BEST-KEPT TUNING SECRETS OF THE PRO'S
One of the best-kept secrets of the most experienced nitro racers and engine tuners is that you can net some serious horsepower gains by experimenting with various glow plugs. As mentioned earlier, a glow plug is the ignition system for a nitro engine. Anyone who has ever worked with spark-ignition systems knows that ignition timing can have a profound effect on engine performance. "Ignition timing" is when the fuel mixture is ignited in relation to the position of the piston and crankshaft during the compression stroke. When the piston is at top dead center (TDC) of the cylinder, the crankshaft's journal, to which the connecting rod is attached, is pointing straight up. This puts the piston at the highest point of its travel in the cylinder; therefore, the crankshaft is at "zero" degrees. The crankshaft must rotate a full 360 degrees to make a full cycle, so the amount of crankshaft rotation in degrees is used to measure the events that take place inside the engine; for example, ports opening and closing and ignition. Although you can't measure or definitively set when ignition takes place inside a nitro engine, it helps to be able to visualize what's happening when you experiment with different plugs. Let's say, for example, that the fuel mixture is ignited precisely at the moment the piston reaches the very top of the cylinder. This would effectively mean the ignition timing is taking place at zero degrees of crankshaft rotation. Installing a hotter plug in the same engine makes the fuel ignite sooner because less compression is needed to heat the plug's element to the point that the fuel will ignite. Let's say that now, ignition occurs 10 degrees before the piston reaches TDC. In ignition-engine-- speak, that would mean that the timing is set to 10 degrees advanced, or 10 degrees BTDC (before top dead center). What does all this mean? Simply knowing that plug temperature will affect when combustion takes place will, hopefully, help you understand why choosing the proper plug will improve performance. Generally, it's best to try to advance the timing or flash point of the fuel-in the case of nitro engines, as much as possible without going too far. If the mixture is ignited too early, then performance is lost and pre-ignition and detonation may occur. Picco's engineers don't use plugs to tune the engine; they simply find the proper plug for the application and stick with it. They haven't seen much difference in performance from changing to a slightly hotter or colder plug. They do, however, admit that getting too far away from the ideal plug temperature will have a negative effect on power production.
THE FINAL ANALYSIS
We hope you now know more about glow plugs and what to do with them. Most people don't think about glow plugs until they don't work. It's precisely then that this information should be most useful. Just keep in mind that there isn't a magic glow plug that will suddenly make your engine scream as it never has before; glow plugs are one of many elements that factor into overall performance. ,
Here's a bit more info.
Several factors influence the use of the correct glow plug for your engine. Here are some guidelines:
Engine Type
Standard engines (engines with a 1-piece head) are most common. Standard plugs are easily available, inexpensive, and fit almost all standard engines. Standard plugs are installed with a washer, which creates a compression seal with the head.
The new Turbo head. Many new O.S. engines, which feature a special 2-piece turbo head. The biggest benefit of turbo plugs is superior performance. Unlike standard plugs, turbo plugs (identified by a “P†in the description) feature a tapered “seat†that matches perfectly with the head. That creates a superior compression seal and with it, maximum efficiency and power. Turbo plugs are the choice for racers, who want, and need, top performance.
A word of caution: you should never install a turbo plug in a standard engine or vice versa. Doing so risks doing serious (and expensive) damage.
Displacement
Small displacement engines need a hotter plug than larger displacement because larger engines have more mass and retain heat better.
Nitro Content
Use of higher nitro fuels will require a colder plug than lower nitro fuels.
Temperature
The hotter the day, the colder the plugs need to be.
Additional Things to Know:
• Hot plugs promote better idling and acceleration. If your engine runs rough or accelerates sluggishly, a hotter plug will help.
• Cold plugs produce more power and may improve performance if your engine runs hot. The downside is rougher idling and more difficulty in tuning.
• Fuel-air mix not only affects how your engine performs; it can also have an impact on how long your plug lasts. If you run rich, it means that you’re using more fuel than necessary for top performance. Modelers are often advised to run rich during engine break-in, because it helps cool the engine. However, running too rich can also cause an engine to bog down or quit entirely. In addition, it also means that the glow element is being exposed to more contaminants than necessary, which shortens plug life. Running lean means that you’re using less fuel. “Leaning in†an engine has a positive effect on performance. However, care is needed here, because over-leaning an engine can harm it, by raising operating temperatures, and burn up a plug [Tech Editor’s Note: More than the plug might be lost, excessive leaning can ruin an engine!] before it’s time. Do not over lean!
Final Thoughts
Choosing the right glow plug not only improves performance, but can also extend the life of your engine and the glow plug itself. With the guidelines above and the tips below, you’re well on your way to achieving both.
• Buy quality plugs. You’re protecting your investment.
• Store plugs where it’s dry. Moisture can ruin them.
• Use the right glow plug. Follow the guidelines above.
• Follow the proper break-in procedures.
• Tune your engine carefully. Running too lean will make your engine “blow†plugs more often. Proper tuning helps extend plug life.
• Never touch the filament of a glow plug. Doing so can break the filament and ruin a plug.
• Don’t over tighten your plug. Tighten it until it’s just snug.
• Be sure to shim your engine correctly. A plug that’s too close to the piston can cause pre-detonation, which will quickly damage a glow plug.
• Use only a glow starter or 1.5V battery to heat your plug. Otherwise, your plug may burn out ahead of it’s time. Don’t be afraid to ask for help. Experienced modelers have already “been there, done that.†Their experience can save you time and money; and most are glad to help.
• Glow plugs get very hot, enough to glow the filament red or white hot, and removing a glow plug while power is applied can cause burning if appropriate care is not taken. [Tech Editor’s Note: Removing the plug while it’s still being “heated†strikes me as nearly impossible, since any attachment to the plug, that would be doing the heating, must be removed so that you can have access to remove the plug. The only other way to heat the plug is from the combustion in the engine, so if you are handling the engine, it’s generally a good thing to have stopped it running while you “fool†with it.] Special caution must be taken while near fuel sources.
• Some connectors for glow plugs can short circuit and damage batteries, or cause them to explode. Batteries may get hot during the use of a glow plug. This especially applies to homemade or nonstandard connectors.
Tech Editor’s Note: One source of material that can ruin glow plugs is detritus left in the engine during/after manufacture. Before you run any new engine, it’s a good idea to flush, at least the combustion volume, to eliminate as much “stuff†as you can. Flush it with fuel or methyl alcohol, never water. The best way to flush is to remove the head and the back plate and flood the engine with the flushing fluid. If you are uncomfortable removing the engine parts, then take the glow plug out, move the piston down so that the top of the piston is below the exhaust port and run the flushing liquid down the plug hole and out the exhaust. If you catch the flushing fluid on a white paper towel, you should be able to see anything that the flush eliminated.
