rikkidy
- Mission B.C.
How can I tell how many teeth should go in the gear sets? For slipper and spur gears.
There are lots of different spur and slipper teeth numbers I am wondering which go with which 13 - 48 14 -48 16 - 48? Or can you use any combination.I'm not sure what you are asking, but I am using a RR 48 tooth steel spur and a 16 tooth clutch bell. mine is an X with an axial .32 and 2 speed transmission. it will wheelie on command and goes plenty fast......
jam, we're all a modder at heart😉
Thanx fer the input. I assume then a 16 tooth would give bedder boddom end than a 13
