RPM upper arms very tight?
martin34
Hi i am fitting my RPM arms and the upper arms are very tight.The lowers fall down when held up and let go of but the uppers don't(without the shocks fitted).It says not to alter any of the arms as they are an exact fit.Should i leave them to wear in or should i file them?Thanks for any info.
I have to push it down.A tap wont work.A tap will move it but only as far as a tap will?
If it takes effort just sand them a little it may just be the seams from the molding that is making them hang up.
That or you can remove some plastic for the bulk head i had a problem like that and just took my grinding tools until if was good and it moves freely now.
Thanks guys.I mailed RPM and they said i can file them gently a bit at a time like said above.They said they say don't modify to stop people whipping out a Dremel and sanding half the arm off.
