Refilled my big bores i think i did something wrong? Help
xsavage3148
I changed pistons to the 1.6t and went from 30wt to 35 wt in the rear. i wanted to firm it up. It seems its actually softer now. any ideas?
they are ruined! send them to me!
did you change the springs too? the oil only dampens the springrate.
to stiffen it up like you want I think you will need to change springs too
hm. no same springs. I'm pretty sure some of the other guys just changed the oil and pistons and had good results. i don't even know where to get stiffer springs.
Make sure you got all the air out after refilling. That will make them spongy.
I let them sit for a while. no bubbles. maybe too much oil came out when i put the caps on. I'm going to change the pistons to the regular 1.6 tonight and refill.
I switched out the tapered pistons for hte regular 1.6 last night. i must have messed up the first fill since they are much better now. still not so sure if i got the results i wanted. May have to just wait for stiffer springs.
Seems it bottoms out when landing from a big jump
