Quick throttle servo ?
xll-SavageX-llx
★ CaNaDa Eh ★
Hamilton Ontario
Hey guys i got back into the savy some more this week cleaning it up and stuff and i blew my SF-2 throttle servo 🙁
One minute i have T/B and the next i didn't LOL, thank god it was in neutral.
I was thinking of the hitec 5625MG for $50 at the LHS I'm running a 6v hump pack so the speed will be 0.14 @ 6v. I have the hitec 5645MG for steering and that's 0.18 @ 6v ..
Will the hitec 5625MG work or do you guys have some thing else i can try and maybe under $70 ..
Here's one for under $70 that's faster than the one you mentioned.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMUS3&P=ML
Specs for the above mentioned servo link
Specifications
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed (4.8V/6.0V): 0.13 / 0.10
Torque oz./in. (4.8V/6.0V): 111 / 139
Torque kg./cm. (4.8V/6.0V): 8.0 / 10.0
Size in Inches: 1.57 x 0.78 x 1.45
Size in Millimeters: 39.88 x 19.81 x 36.83
Weight ounces: 2.18
Weight grams: 61.80
Here's another one that's slightly more than $70 but alot faster than the one you mentioned and a little faster then the first one I suggested.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTHR5&P=7
Specs for this one.
Specifications
Speed (4.8V/6.0V): 0.10 / 0.08
Torque oz./in. (4.8V/6.0V): 92 / 111
Torque kg./cm. (4.8V/6.0V): 6.6 / 8.0
Weight ounces: 1.87
Weight grams: 53.01
Specifications
Weight ounces: 2.18
Weight grams: 61.80
Specs for this one.
Specifications
Weight ounces: 1.87
Weight grams: 53.01
Thanks xtrem
Is there really a bid deal between analog and digital ?
IMO I wouldn't care to much for throttle speed with a heavy truck such as the savage. The Savage needs a medium between the throttle speed and torque. IMO the Savge needs more torque holding power for brakes approx 170 oz/in and a decent speed for your throttle some where between .10-.14 which is good enough. If you have a good radio and receiver i would adjust the response speed and buy digital servos.
Thanks xtrem
there is if you have a digital Tx/Rx.
If you have a analog Tx/Rx and don't plan to upgrade to digital, theres really no point wasting your $$ on digital servos as you wont be able to realize the benefits.
I'm getting the dx3s in about 5 days..
and at the lhs the digital and analog servos are the same price ..
then you just answered your own question 😉
you can program the dig servos with the dig Tx/Rx
That one will be fine. But if you go with the HS-965MG you'll have a faster speed and a little bit more torque. And it's only $10 more than the 5625MG. That would be my suggestion for a good budget T/B servo.
even better 🙂
the HS-965MG it is LOL
Ill sweet talk him down to 65.. Hey when you bring buisness you should get some sort of a deal LOL. My uncle alone has spent 9k in the lhs, he has 3 bajas..
