Purenitro
Owner of Extreme RC Mods
Here is a pic that Bad took and I edited, as you can see from the green arrow there is no way for the back plate to sit flush against the engine block, the raised area around the bolt hole will prevent this from happening. The holes in the block are meant to only receive the bolt, they are not countersunk so there would be gaps all the way around the plate. The blue arrow indicates that the raised section goes right up to the section that goes into the back of the block, this would prevent the use of any O-ring for sealing. I looked at this piece long and hard and found no feasable way of making it work (short of gooping it up with sealant) I'm not sure of an alternative plate but this is not the best choice.
