Project: Bulletproof Basher
No problem man. Here you go, I'll give you pictures of the battery box, reveiver box, the tank and both servos:
-Josh-
Yeah thanks again for the comments guys. Yeah only like 3 screws have come out so far and the tires hum down the road. They're stockers so I don't care about if I wreck them. runoverbysavage I understood what you said in a later post. But I still don't think the stock drivetrain would hold up though. And I put it in there to be bulletproof.
-Josh-
It will hold up for awhile I still run the stock dogbones and cup joints along with the stock dif cups (with the 4 bevel gear) OOOHH yea I have my share of snaped dogbones I think i have snaped everyone at least once.. And lots of bevel gears But sence I shimmed the dif I haven't really haven't had a problem with them.. Also I Have a good tip for thoes people out there that have access to a welder (put a small tac weld on the dogbones({were they get smaller right before they start to go into the cup joints} I have done this and haven't had any snap so far.... I do plan on getting the alum.. dif cups and heavy duty dogbines and cup joints..sometime.........
Good idea I think I am going to get my dad to weld the dip and grind it to make it tougher.
-Josh-
yes it works tac weld it on both sides and then grind it smooth (it doesnt have to be perfectly smooth u do want some of that metal on there
Okay guys sometihng finally came in the mail today, my 3-Speed and my CNR Dual Disk Brakes:
-Josh-
Thanks man.
Okay guys finally my ignitor and 18T vented CB also came in today along with my LST Shocks!!! Here are a couple pics of the shocks and stuff you might not have seen:
-Josh-
Thanks for the comments guys. Me and my friends will be starting a video soon and will be finished in a couple months as we want it to be good. Hopefully our camera man holds through!!!
-Josh-
Here are some long awiated updated pictures.
Yes those are ghost flames.
Then it changed up a bit:
After I got my STS D30M Rev 2 P+P:
Couple days ago:
0702 Pipe:
Tank and mounts:
Talk about barely any clearance for the horn and cup:
Radio box setup (sorry it's a bit messy):
Enjoy!!!
-Josh-
