Problem with my Carb
Rmadrid7
Houston Tx
Hi everyone!!
I have a problem with my carb throttle.See pics. Is there a way to change where your hook the linkage? I try to lose it, but i am afraid to break it. Some advice is welcome.
Thank you
It will be easiest to remove the engine to access the screw securing the arm to the slide.... make a mental note where you want it, loosen it up move it into place, I would move it so it points toward the spur a bit more and try to make it level and straight as possible and make sure to locktite that screw again. I have seen many of them vibrate loose and some actually lose the entire arm also.....
thanks Jam for the help
