Problem with clutch bell sticking on spur gear al
GLISEON
hello everyone I've been a having a minor problem yet still something i can't figure out. I bought a new set of both gears (clutch bell/spur gear) by Robinson racing. Seems like it got unmeshed and the gears started to crank together and make this horrible sound. The gears aren't stripped but whenever I try to turn the spur gear left ( the direction the car drives forward) it gets hard on the clutch bell like if the bell got chipped. Any ideas? Any problems similar to this?
Possible that the mesh is off due to something being off in the chassis. I'd check to make sure nothing looks damaged or cracked. Or that all fasteners are tightened and that everything looks like it is lining up correctly.
You could post up some pictures of the area, maybe we will see something.
Could also be that you got something between the gears and bent the input shaft. Pull the engine out and make sure everything spins true.
