problem with brake and carb
ikesavage
Canosburg
I have been tring to fix the problem and I can not see how, whats happening is when I hit the brake the carb is closeing and most of the time it stalls. I have the different set up from ofna but haven't put it on yet the reason is cause I am doing a total tare down this winter cleaning updating and replaceing or upgradeing changing repair anything that needs to be done but untill then I just want it to run for now any help please.
yep if your trucks stalling when you apply the brakes its the idle!! take off the air filter so you can see into the carb and adjust the idle screw till there is a 1mm-2mm gap should be ok then!!
no not all the way, if your carb is set at 1mm - 2mm you can hit the brake as hard as you like it will not stall, so if it is set at one of those settings your carb will not close all the way and there for it should not stall,,,,, hope that helps
Check the bias or gain on your radio. You may have it so the servo pushes it to far in that direction.
