wildchild27
DR. DISASTER
- Etna Green, IN
here is the same crank that both the truggy version and pullstart version use.
part number (LRP38575) ZR.30 Crankshaft $75.99
backplate (38557)-(pull start rear parts)
owb (38491)
the lrp zr30x has a 7+1 port sleeve and the lrp zr30 spec2 has a 5+1 port but both use the same crank which means you can use the pull start equipment on the truggy version. but remember the pull start and owb reduces the overall performance of the engine.
here is the link for the parts list for the spec2
http://www.lrp.cc/fileadmin/lrp_anleitungen/anl_25002_ma00191-lrp-zr30-spec2-pullstart-manual-e.pdf
and here is the link for wat both mills use.
http://aedownloads.com/press/in_022309_lrpengines.pdf
owb (38491)
