Hypnotiq
I - AM - HYPNOTIQ
- Lake in the hills, IL
MotorSaver said:Motor Saver
What you can expect from the new Outer Saver pre-filter:
Oiled foam attracts dirt quickly, causing foam filters to clog in a short period of time robbing power from the engine depending on your driving conditions.
* Outer Saver repels dirt for a much longer period of time giving you many more tanks of gas before cleaning.
* The rim helps separate the screen from the foam allowing for better breathing and better separation from the oiled foam.
When driving in high-moisture or wet conditions, foam filters allow water or moisture to travel into the carburetor.
* The new Outer Saver repells moisture and water keeping foam dryer longer.
* The new Outer Saver pre-filter can easily be put on and taken off by the push of a button which bites into the cord keeping the pre-filter wrapped securely.
* Lead ropes coming out of the lock are short so they do not interfere with any linkage or gearing.
How long them ropes gonna be? I can the them getting caught in the spur. YIKES!
