Outer Saver Pre-Filter By Motor Saver Filters
Hypnotiq
I - AM - HYPNOTIQ
Lake in the hills, IL
attachment.php
attachment.php
MotorSaver said:
Motor Saver
What you can expect from the new Outer Saver pre-filter:
Oiled foam attracts dirt quickly, causing foam filters to clog in a short period of time robbing power from the engine depending on your driving conditions.
* Outer Saver repels dirt for a much longer period of time giving you many more tanks of gas before cleaning.
* The rim helps separate the screen from the foam allowing for better breathing and better separation from the oiled foam.
When driving in high-moisture or wet conditions, foam filters allow water or moisture to travel into the carburetor.
* The new Outer Saver repells moisture and water keeping foam dryer longer.
* The new Outer Saver pre-filter can easily be put on and taken off by the push of a button which bites into the cord keeping the pre-filter wrapped securely.
* Lead ropes coming out of the lock are short so they do not interfere with any linkage or gearing.
How long them ropes gonna be? I can the them getting caught in the spur. YIKES!
MId summer (dusty) I use panty hose to do the same thing when mom sister or girl gets a run they are free.... Oil them for the best effect
the string is a little long, but tucks up between the outwear filter and the stock filter. Have not had any issues with the string getting caught upo in the spur.
Bank, I think you should do a full write-up on the pantyhose mod. *snicker* 🙂
The newer SAV100 filter has that same material built-in doesn't it? Correct me if I'm wrong, but is this really necessary with the newer MS filters?
This is a pic of the SAV100 from tower hobbies web site where i orderd my filter for the savage xl.
And this is what the filter looked like [ black ] when i recived it. Minus the dirt.:lmao4:
The package had the letters and numbers SAV100
