Oregonmuds racer
Those are Traxxas throttle linkage slides and stops. There is an OFNA throttle linkage kit that has the same type of pieces and some other parts you can use too. Some clevices, a 6" rod, a spring from a ball point pen, ball ends and turnbuckle from a RS4 and your almost there. Just have to put it all together.
I haven't been able to mount my center skid plate yet. I have the old style FLM TVPs and the new skid plate. They wont work together without being modified. So do you mean the actual skid plate is touching or the Skid plate brace is touching?
Thats a good idea to space the plate down some. Just put a washer in between each brace and the skid plate and that will give you more clearance. Good luck with that, it sounds like you are on the right path.
