Depends what specs we're taking about and how much load the engine is under. Most dyno's and spec you'll see state where the peak power is made, thats not to say thats where the engine will spool out to just at what point its generating the most power.
CY dosn't seem to really publish spec sheets but the Zenoah equivilant the g230 is spec'd with a peak RPM of 19,500:
http://www.zenoah.net/products/hobby/download/G230RC_G260RC_704.pdf (page 5)
Although thats not under load, gearing, tyre size, pipe, vehicle weight, where you run, etc, will influence the actual load rpm. And what happens when your on a loose traction surface and you break your tyres free? those RPM's are going to soar and many like to drive that way, kicking up as much dust, powersliding all over the place and trying to get a little drift action going.
There isn't a huge difference between the Zen's and CY's in raw performance, we've got a mixture of both in our bashing circles and dragraces are really a toss up. The same is true of any engine inc. garden equipment, all will rev lower when under load as will these engines.
Synthetic oil is pretty much all you find in most bike shops these days... unless you ask them to get you some nice castor blend from the back room, its not because synth is better its just due to vehicle emission laws and not having smoke pouring out of your pipe as you ride down the street, but the rules are a little more lax for race oils, thats what i'd recommend anyone buy.
