AllanQ
- St. Marys, Ga
Can you post up some pics of your current setup?
Foward throttle is great but when I go to apply brakes all that happens is I am putting so much strain /stress on the steering crank. My servo wants to pull the crank off the frame of the truck.
Thanks.
yea, pics & if you can also identify what you mean by 'steering crank' with a part # from your manual it would help.
we can prob help you with a easy fix, don't get frustrated.
I stole this pic from WHIPNET hope he doesnt mind. Should have asked him first.
No sweat man.. that's why they're posted.
love my savage, Almost don't want to run it.
Is the spring setup in front of the server arm for the throttle? Is it catching or sliding forward as it is supposed to. It needs to be able to slide so it doesn't pull the throttle when braking.
With the throttle on top, the first pic is neutral and the spring is not compressed and the arm is in the middle of the linkage slider.
The 2nd is 100% throttle. The arm pushes against the rear standoff.
The final is what I mentioned.. at 100% brake, the arm should not move your throttle forward much. It should slide and compress the spring. Giving it some tug against the throttle, but not enough to rip the mixer off. I got an aluminum mixer to take the slop out.
This is not the only way to do this mod. This is just how I did it.
By the way Whipnet, where is your screw that goes into the threaded spacer. I'm talking about the aluminium spacer that goes inside the purple plastic pieces that attach to the servo arm. I don't see it.
Congrats on getting this done. If I am understanding correctly you are talking about where the slides connect to the servo horn?
Do you have pictures of what you are talking about? Or can you point them out in my pictures with an arrow?
I can post a pic but not at the moment. How do I show you with an arrow? I'm sorry for my lack of computer knowledge. If you look at your pic, inbetween the two collets you have your plastic slides. I have a screw that screws into the aluminium insert that slips into the plastic slide, I don't see one in your pic. I was just wondering how you attached everything.
OK, I think I know what you are talking about. What appears to be a hole connecting the top and bottom sliders to servo horn.
It's been a loooooooong time since I did this mod. I think I might have come up from the bottom, but I really don't remember. I will get home and take a look at it and take some pictures of how I connected it.
OK thanks, don't worry about it I was just wondering how you got it to stay together without the screw. I have a lock nut on the bottom holding the screw in place.
No worries.
I have the screw coming from under:
Fixed the images for you. Looks great man.
nice work whip, not gonna get much better help than that right there :resp:
